Quote: a little rubbing with a soft wheel brush in a dremal should take care of the bad spot in the venturie.
Well, the metal's definately eroded here, it's not tar that you're seeing in the photo. I do have a dremel and a wire wheel for it so I could at least smooth out as much as I can on it.
Also, after I've rebuilt the engine I've run ONLY ~92 octane (supposedly) ethanol-free gas. I say 'supposedly' because I wouldn't be surprised if they add a little to the gas anyway.
But it sounds like that's normal 'wear and tear' and that the carb will probably run ok as-is (aside from removing the tar, and I'm almost done with that)?
