Quote: the new rotor with the .060" longer blade and it fits great- a much smaller gap than with the original rotor, and the rotor tip misses the bases of the plug wire terminal posts by at least a 1/8". So it looks like the original problem is taken care of...
Not yet , 1/8" is way too much, we want the tip up to the same height as the vertical part of the metal cap terminal and as close as .010-.015" laterally to the terminal(s) tho it will be more than that (unmodified) even with the MO 3000 rotor
