GREAT THREAD!!!!
I have 64 B-Body with SSBC-A156 Disc Brakes and poor braking performance with a hard pedal feel. Specs: Rotor Diameter: 11,25 4 Pistons each 43 (mm I guess) = 1,69' x 2 = 2,39 for the calculator Master Cylinder bore: 1 1/32 = 1,03' Pedal Ratio not measured, taken 7' from the file
With the specs I have calculator shows torque 3100 and pad movement 0,0047. When I change to a 15/16 MC torque raises to 3824 but pad movement just 0,0039.
If I change the brake pedal move from 5 to 6 inches due to other stroke pad movement goes up to 0,0047.
So I might improve braking torque about 20% with a 15/16 Master Cylinder. I was thinking of buying a 1975/1976 A-Body master but they are all power units. Any other 15/16 Master recommendations?
Many thanx in advance
Dr Diff (Cass) is the only one I am aware of that sells a 15/16 manual master with the groove to keep the pushrod in place. He machines the groove in place himself. I just bought one, and it's sitting waiting to be installed.
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
