I understand all that, but it' not as obvious as it might need to be for some.
Anyway, one other thing to consider when using your formulas is the capacity of the m/c and the needs of the calipers. Not enough volume out of the M/C and the calipers will not do the job, which is what I think FD had for a problem.
Steve - what does the power booster have to do with the volume output from the master? The only time that is going to make any difference is if he ran out of pedal before the brakes were fully applied. In that case, he could have also cured the issue by going to a larger diameter bore on the master. So, was the root issue too much pedal travel?
Michael
Plano, TX
68 Barracuda Notch Pro Patina
