one bit of math missing here.
relationship of piston stroke in the M/C versus pedal ratio.
Someone here thinks less leverage is less stroke at the M/C
Less leverage is less stroke at the pedal. Stroke at the master is determined by the system downstream.
Stroke at the pedal is irrelevant. Stroke at the M/C is, Frankenduster had an issue with his manual all disc setup I am thinking is volume out the M/C related. The problem cured up with him swapping to power (less leverage at the pedal, more stroke at the M/C, same MC).
In a lever situation, which this is, stroke and leverage are directly related.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
