Re: HP for $$$
[Re: Mr.Yuck]
#1037571
07/23/11 10:55 AM
07/23/11 10:55 AM
Posts: 52,972 Romeo MI
MR_P_BODY
budget build 550hp how much $$ are you going to have in the small block.how much $$ are you going to have in the hemi.and then how much money will you have in a 383 400 or 440.
right, nobody said you can't make 550 w/ a SB, but it can be done much easier and cheaper w/ a BB. I didn't add Hemi's because hey are too expensive for most. I've know guys that took a lower milage 440 apart in the grage, re-ring, quick hone, new t-chain, cam, clean up the heads, reassemble add used intake, headers, 750DP and run mid 12's in a heavy B-body. (BTW that's 11's in an A-body) Not going to do that w/ a small block. Not as cheap anyway.
I think some of you need to do a actual price comparison to see whats what... take a head and price the same head in both BB and SB and do the same for the rest of the parts to see what the price difference really is(dont take a cheap 440 part to a expensive SB part... try to make it the same part)... yes I know I can buy the big dollar heads for a SB and have to get all the pricey stuff thats needed to go with them
