No one is going to try to make 600 hp with stock pistons, so that's not even an issue. It'll be far easier to make the hp with a larger engine, though.
Of course, the cheapest way to go fast is Nitrous.
R.
You cant get close to 550hp on a stock 440 flat top short block with the right set of heads and cam, I bet there are some very close..... My point is its not possible with a low compression 360... so the 360 would cost much more in hardware to even come close... We are talkin low budget right.... as for power adders a stock 440 / 375hp engine with a 150 plate makes around 525... thats close, a 360 at its best with a 150 shot makes 370hp ... not too close
