This class is called ProStreet, but doesnīt have anything to do with your class with the same name.
Basically a fixed ET bracket racing but with a Pro tree start, which is all I want to race. Only door cars, with minimum weight breaks for Big/ small block and a penalty weight for clutch.
A new faster class called SuperProstreet started last summer with 6.90ET and no minimum weight, and would fit my Haas car even better, but way out of my league for engine budget.
I have not raced since 2002, and that was with my Coronet-69, so I donīt know exactly how many events this class has total in Sweden. Probably about 8-10 weekends.
I will start out slow, without spray in ET super pro, even if I donīt want to run handicap starts, but I need seat time and sort out bugs N/A before I will buy a nitrous converter and a fogger.
With good( constant) vacuum in engine and no big changes in valve lash, I plan to keep the engine togheter for the whole summer, thats a big if....
