Quote: this class draws cars and people to the stands
from there site: Outlaw Limited Street 1/8 Mile, Heads Up, .400 Pro Tree, 32 Car Field, Sportsman Ladder, Lane choice goes to higher qualifier first round, and then the faster car from previous round.
Rear Tires 29.5" x 10.5 non W or 315 drag radial or smaller
Front Chassis/Suspension Stock front frame rails and suspension required. Aftermarket control arms and bushings allowed as long as they bolt in stock locations. Rack and pinion steering allowed. Aftermarket coil over shocks allowed and aftermarket direct replacement struts are allowed, but must bolt in stock location.
Aftermarket bolt in sub-frame allowed. Must bolt in unaltered stock OEM mounting locations. OEM suspension configuration required. These bolt on subframes must be from a manufacturer with designated company part numbers and must be produced for the vehicle they were designed for from the manufacturer.
Rear Chassis/Suspension Any type rear suspension allowed. Firewall must be retained and in stock location.
Engine Any engine combination allowed. Motor plates and solid mounts allowed. Mufflers required for all cars except turbocharged entries. All nitrous bottles to be safety vented pop off to outside the vehicle.
Transmission Any type automatic or OEM manual transmission allowed.
