I'd be in.......and Smothers Supercars will throw $1,000 into the pot also......
I like 1/4 mile racing, but I think 1/8 would be better for this so the racing would be closer.......
So, will it be 100% Grudge Run What You Brung, or will there be rules?
If there will be rules, how about this?
Mickey Thompson
any tire marked to 28.0/10.5 including the W tire
any tire marked to 29.5/10.5 non W
Mickey Thompson ET Street
any tire up to the 28/13.50 or 30/12.50
Mickey Thompson ET Drag Radial or
Hoosier DOT Drag Radial
any Radial no larger than 15" wheel diameter.
Hoosier
any slick marked to 29.5/10.5
[the 18192 and 18175 tires are not legal]
Phoenix
Goodyear
any tire marked to 29.5/11.0
......and something like this for weights?
Blower or turbo big block 3450 lbs.
Nitrous big block 3450 lbs.
Naturally aspirated big block with non conventional heads 3250 lbs.
Nitrous small blocks inline heads 2900 lbs.
Turbo small blocks 3325 lbs.
Blower small blocks 3375 lbs.
Add 100 lbs. Alcohol EFI and Mechanical Injection.
Add 50 lbs. cast tunnel ram, 2 carburetors.
Add 25 lbs. ladder bars. (Classic Car*, all Trucks no addition)
F-1R blower Deduct 50 lbs.
Classic Car* Deduct 50 lbs.
Truck Deduct 50 lbs.
Leaf Springs Deduct 25 lbs.
Naturally aspirated deduct 300 lbs.
Any Tire factory specs for tread width less than 10.2" or diameter less than 28.2" deduct 25 Lbs.
Any DOT tire factory specs over 29.5" diameter and 11" tread width add 25 lbs.
I just copied the rules from the MakoTenFive website........
