Quote: No gutted race cars, interior, roll up windows, no back seat ok but must be carpeted? tt5 or 315 tire. BB power adder 3300lbs Smallblock power adder 3100lbs NA BB 3000lbs NA SB 2800lbs street appearing is the key. Must post pics of your car efore the race with its weight.
how about these for rules?
those rules look great.... the only thing i would change is to allow weight breaks for guys using factory blocks also you need to have some rule about heads...Preadators or B1TS or B1PSO are a lot better than 440-1, calssify them as Non Conventional Best thing is use the above weights as base and deduct from there
Deduct for factory block Deduct for conventional heads
not looking to complicate the rules any, just give weight breaks for people running "cheaper" or more common equipment
