Originally Posted by bigdad
if its so easy, then why did a pro builder fail to put it together correctly ?
Some people bring in help when they get swamped and don't check the work of the helpers. I built my first 727 when I was 15 years old and close to 30 more since then and all you need to do is pay attention to details and you will have success. The only failures I had was when the owner installed the converter the wrong way, not being careful with the alignment and damaging the pump bushing or the drive lugs.
Gus beer
64 Plymouth Savoy
493 Indy EZ's by Nick at Compu-Flow
5-Speed Richmond faceplate Liberty box
Dana 60
