Originally Posted By GoodysGotaCuda
Originally Posted By pittsburghracer
So I’m guessing you didn’t degree the cam in.
Nope. There's no reason why it shouldn't run fine installed dot-dot with two different timing gear sets.
So you'll have no idea where the cam timing and evidently you don't care.
Try and not be offended when I say that you shouldn't assemble engines. For you, or anyone else. Until you learn how to degree a cam, and WHY you do it, every single time.
I can give you reasons why dot to dot is a bad way to do it, but you wouldn't care.
There is no reason EVER to skip the simple process of degreeing a cam. EVER.
Just because you think it won't make it true. Horsepower is KING. To dispute this is stupid. C. Alston
