Just something to think about. Fuel pressure means that there is fuel at the gauge. It does not meam there’s fuel in the carb. I have to run the bigger needle and seats or I will drain the float bowls. Also I run a mechanical and electric pump together. I have forgotten to turn on the electric pump and it acts just like that 4000 just cuts out. Rpm drops comes right back.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
