Based on the builds I audited, the RB26 etc. comes close to 2JZ... except for the amount of prep. The RB has larger valves, minor dome tweaks, more cam duration, larger intake plenum, blah. The JZ is stock X stock X stock X stock, blah. Heads up, stock engine with zero zero mods except for boost, the JZ walks away.
