Thanks. Should have stripped the car before starting. Customer bought it under the impression it was ready to paint. After welding in the rocker beams, the heat flaked the primer off the rocker. Underneath was unscuffed original B5 blue. Knew at that point a total strip was going to be needed. Found many areas that surface rust had been primed over.
It will need a full right side quarter due to a very poorly installed skin, but everything else is workable.
Next up is seam sealer and coating the bottom with bedliner. Customer wants a driver, not a show car. VERY happy to accommodate this!!! Install suspension and roll it off to body and paint.
