Been doing a little work this week. Roughed in the dash.
This is just to build the mounts for the dash frame. The pad will still need to be tweaked and upholstered. More on that later. Still just fitting!!
Removed the rear floor section.
Leaving only this...
Cut it in half and called the junk man...
Pretty sure were at the point of no return now!
Fit the kick panel plates. This attaches the firewall to the existing inner structure. This allows me to mount the E-brake pedal and locate the wire pass through for the doors. Still working here.
