Thanks for sharing that info, one more inquiry and back to lurking... The dash. Did you get a picture from the top when you 'test-fit' the dash? I'm curious about HVAC and if there is going to be some re-routing needed because of the lack of dash real estate. I finally have a frame coming in the next two weeks. I may actually get this thing started this summer. As always, wonderful work and thanks for sharing your experience. John
