Boogers and dogdays posts should be plenty to enlighten you. Im very familer with the term and its easy to understand.
You can only do so much area under the curve with a certain lift, diameter will regulate that. It was well explained IMO
So yes a Chevy type diameter LOBE design can be ground on a Chrysler LOBE. Its still a Chrysler cam, but its got a Chevy Lobe.
hey, we all cant know everything
EDIT, Also Im not Implying that Dragula has a Hemi cam with a chevy type Lobe design.
