Quote: Well, the engine got down to the shop...We discussed going to a 528 and a real cam somewhere in the .640 lift range. And maybe a real convertor...
Depends on what you are going to do with the car
An 8" vertor will definately make better ET. But you may not like it's street manners.
Do the test to see how long it takes to fill a gallon can using the lines from the regulator. Don
