Well I got out a can of starter fluid and started spraying once I got it warmed up. I can go all the way down the drivers side head and around the carbs with no increase in rpm. Then when I go to the back of the passengers side right below the coil the rpm will go up a couple hundred rpm each time I spray around there. I also hear a sound which I thought was an exhaust leak in that general area but I am thinking it must be an intake gasket leak. Would that normally make a sound like an exhaust leak though? Definetly something not right back there so looks like the engine builder did not get the intake on correctly and now we will have to pull it. Anyone have any input before I crack it open??
