Update as I just got done working on it.
Well now I am really getting frustrated as it will not start yet. I have replaced the ecu with chrome mopar one, the resistor with MSD .80, and the fuel pump with a 150 gph mechanical pump. Still did not start. I checked the coin for spark, it has a big spark and about knocked me on my butt as it arched across the metal and came back and hit me! then I pulled a plug wire to make sure it had spark at the plug. Yes it had good spark there. Poured a little gas in the center carb and it fired off.
My only other thoughts are the fuel filter or the sock inside the tank?? I am going to pull the filter tomorrow it is brand new "date code" correct metal one. Has anyone had any problems with those??
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
