Your rod bearings will be hammered, the 3 center main caps will lose their register and will metal transfer to the block, pistons will lose their ring lands, with a TRUE 48 degrees timing, like 20 at the crank and 28 in the dist. All problems I have seen with hero timing like that. 38 is the correct MAX timing for a bb mopar, no argument on that, 1/4 mile or granmas grocery getter. If the cam is in wrong 48 might work??
