I am not trying to contradict Tom Quad as he is always helpful, but Mr Six Pack, Bob Karakashian uses a 160 degree thermostat in his pure stock 6 pack Super Bee, and does not think the 195 is required...
He also recommends 38 -40 degrees total timing and no vacuum advance for performance use. Granted he does run real race gas and has 11 to 1 compression which is allowed in pure stock.
Good luck with it!
Arnie
Regardless whether you have 50 cu.in or 500 cu.in,depends on your end goal,street or strip !
