Oh....and I might add that I had to switch the springs on the outboard vacuum chambers to the purple springs for that XE295HL ..... the small yellow ones just came on a little too quick....that really made the transition to the end carbs a lot smoother.
Like said, that cam should make that engine a real strong mid range "pull -like- a - freighttrain" runner. Get that timing up there...
