Well I got the carbs all figured out as it was the linkage binding as the outboards had the linkage a little too long and this did not allow the center carb(or outboards) to close all the way. Well I got that figured out, the idle down and the timing bumped up and I was rewarded with a set of black marks about 75 feet long as it is a great low end motor. But it seems to lay down a little on the top end when it should not be?? Then to top it off I pulled it into the garage the other day and it would not start(which is in another thread here) and I replaced the fuel pump and today a new chrome mopar ecu showed up and new ballast reistor so we will see if those fix the no fire issue. Hopefully it will start, run smooth and NOT lay down on the top end.
