That tail housing/shifter look totally different than what my B-Body trans has? What does the crossmember look like?
I got my trans back in the Coronet, and I am changing the crossmember spacer from 1-1/2" thick to 1-1/4" so the transmission will fit in the modified tunnel without modifying the new trans tailshaft.
