Thanks for all the input. I should have my SS700 next month. Going into the '69 Coronet 4-speed car, and I am using the stock clutch linkage / mechanical throw-out bearing, so it may use a different retainer? I ordered pretty much the entire kit except clutch linkage, so it will be coming with Keislers bellhousing, inspection cover, console shifter, clutch, pressure plate, etc. I'll post some pictures when it shows up.
