Re: '71 Duster Front Suspension Woahs!
[Re: cageman]
#1201270
04/11/12 12:09 AM
04/11/12 12:09 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Explain why a threaded body is advantagous? Heim ends on the street arent any good, but I guess you think it is. schrader valve, and rebuildable, why would I need that, they are adjustable. Unless you like to change oil every ten miles, then by all means. But to bad they are too long, you bottom that bad boy out, you ruin the end cap and seal, where the snap ring end caps give a little.
And here I thought I was a cityboy, guess not.
an externally threaded body allows the end cap to be threaded onto the outside of the body instead of into the body. Couple that with a welded shaft eye and you can usually gain 2" of travel to a similar travel shock but in a 2" shorter compressed length. I'm not an ex bilstein employee but I have figured that much out working with King on my old truck.
Mopar to the bone!!!
