Quote: So the issue I'm having is that nothing fits right and after months of hassle I'm forced to throw some 15" steelies back on the car.
Needs to be spaced out away from tie rod. Is it hitting the upper ball joint, inner frame rails, and/or sway bar too?
Quote: Driving the car gave me horrendous bump steer -with how low it is- because the crappy KYBs were on the bottom end of their travel and rendered themselves useless.
What is it doing?: Feels loose, jumps from lane to lane, feel every crack in the road...?
I doubt it's actual bump steer (toe in/out during suspension travel). I just measured it in my A-body and it was pretty darn good.
I've run KYB's with the car very lowered. What was the distance between you LCA and frame?
