Explain why a threaded body is advantagous? Heim ends on the street arent any good, but I guess you think it is. schrader valve, and rebuildable, why would I need that, they are adjustable. Unless you like to change oil every ten miles, then by all means. But to bad they are too long, you bottom that bad boy out, you ruin the end cap and seal, where the snap ring end caps give a little.
