Quote: With the delay box you still have to let go of the button just like any trans brake car with out a box. If your late your late with or without a box. The only difference is how you adjust to get the the light you want. Without a box you change the car to get the lite you want within the limits of the car. The delay box does the same thing.
it is just more simple to electronically setup your rollout.
