Changing the rules to a .500 tree would be interesting. I managed to get some .0 lights this past weekend in 10.0. They were in the .060 - .070 range but when you get a .027 strapped on you by a lighter car it's all over real early when someone can drive the stripe. Will continue to run the class either way as I find it a blast.
Kudos to John Cope for sponsoring the class as well!
I think anywhere from 40-70 is paying attention when you dont have a box and have a heavy car, that is pretty much the range i was in all day in 10.0.
But as you said, when guys go 013 on you, and there is no way in the world you can get a heavy car with no box to do that, as you said its all over.
I say let em keep the boxes if they must, but have the race on a 500 pro tree, like it originally was to begin with.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, low 10.30’s 1/4 1.41 best 60 foot 6.56 at 104.17
