I don't think taking out the delay boxes would keep anyone out. You can still let some air out of the fronts, bring down your launch rpm, shallow stage if you're not already and if you can, adjust your trans brake button for more travel.
Yes Pewter & Blue 67 Valiant. Was a nice light you had. Obviously I need more practice with the .400 pro tree but I'm getting better.
I have weight in the car and a throttle stop on it now to slow it down but thinking about going the other way and trying to race the stripe as others are doing. From what I saw your running well into the nines in Pro yourself. Congrats on the win.
Thanks. You may be losing a little reaction time by using that throttle stop, found that out for myself in Pitts. I can pull it off in my '81 Charger, but the Dart doesn't like it for some reason.
