What did you ever do about the cross member you cut out? Never saw a picture of it being reinforced. The floor sheet metal alone isn't going to cut it. I'd fix it now before you possibly damage a very expensive purchase. Doug
I have not done anything with the trans member or floor yet.How/what should I do to it?to start I was going to fill in the open area with 1 piece .125" thick and as wide as the frame bolt holes
The big box hanging off the back can be cut off for a smaller[1"x4"] shelf the the trans mount will bolt to.I am not against making a whole new trans mount but I am using what I have to progress on other things.Your input is welcome.
