The Ignitor I and II HallCell modules/magnets have an adjustable air gap, only the Ignitor III adjusts the Dwell (gap) electronically, the gap is .030, find anything other than metal (plastic, paper,etc,etc)that is non conductive or magnetic to gap the Dwell angle
This kit doesn't really have any adjustment potential that I see unless I start machining things. It has two small round holes that just fit over the small posts used to help locate the condenser and a round hole for the screw. The holes aren't slotted to allow for movement. I've seen the 0.03 gap listed in multiple places for different kits, but for this one it's like it is made to only go in as is. Maybe that's why it didn't come with the plastic gaping tool included with other kits?
