This 1384 ignitor kit didn't come with anything to set the gap between the module and the magnet and it looks like it's not supposed to. So, is there a way to make sure it's in the right place?
The module has a hole in the center of 2 other holes that allows for a screw in the same place as the one for the condenser. It has two other holes, one on each side of the one for the screw, that fit over a couple of small posts that were locators for the condenser I assume. I haven't tried to start it yet, but it looks to me like a fairly large gap between the module and the magnet so I want to be sure if it doesn't crank whether it's the position of the module or the timing being way off.
The Ignitor I and II HallCell modules/magnets have an adjustable air gap, only the Ignitor III adjusts the Dwell (gap) electronically, the gap is .030, find anything other than metal (plastic, paper,etc,etc)that is non conductive or magnetic to gap the Dwell angle
