so motor, trans and front k-frame are all out, not fun by yourself btw
pulled the intake, and pulled all the plugs out, hooked up the compression checker hose ( pulled the valve core out) made sure it was a tight seal, pulled the rocker gear so i would have to keep rolling the motor over for tdc, put 110psi to it and i heard ait hiss from all eight cylinders, but no bubbles...........not a single damn bubble, I am thinking about putting a thermostat in it and running it on the "factory motor stand" and run it, other wise i pull the heads take them to the machine shop tomorrow, have them pressure check, hopefully at no cost to me since they have told me with 2 magnafluxs that they are good and then I dumped soo much $$$ into iron.... frustrating, I am open to any ideas and suggestions guys,
-Mike
