got everything but the torque converter, flex plate, just real quick I am looking at roughly 9.5:1 compression with my build, what would everyones recommendation be for a DP carb and would a 2400 stall be a enough to help motivate my 3400lb 2dr volare with a 2.94 rear gear ? or should i be looking for a higher stall ?
-Mike
The answers are out there you just got to look hard enough
