When you say "bumpsteer is not a problem" what do you mean? Did you measure it? In my experience toe change through the travel is excessive on those front ends. Since ATS went under, I though someone else made a knuckle with a drop arm. That would eliminate the need for the spacers at the tie rod end. It would create a much stronger connection along with the ability to bring the bumpsteer into a normal range.
