I have the XV Level II. Had it on the car for 5 years or so. It's a very good suspension, I've raced the car on a roadcourse several times, I've used the car for vacation/long trips and just cruising the streets. The only thing I have done to it is change the stock (Corvette C5) uprights for LG Motorsports Billet drop spindles to get the rideheight right (with the right alignment). No bumpsteer issues whatsoever. I can highly recommend it.
I do agree that a proper setup stock suspension like Hotchkis or the XV Level I would be good alternatives and probably just as capable (have never tried one of those tho) on the streets. However the XV has the weight reduction and the Rack and Pinion that is just a dream to steer.
With the original C5 upright.
The LG Motorsports drop upright.
With the LG installed.
After a track session with rubber build-up on the tires.
