If you have 90\10s or 3 ways on the front and single adj on the back, you can only afford to buy 2 shocks, which one do you replace
If your car doesn't have a wheelieing problem I would go with rears. If it's pulling the wheels a lot then I would want fronts. But I don't think with your gears you have a problem in the front.
That was a very nice way to tell me Im slow. Ok, lets say i start spraying a 150 shot on it. Then fronts or rears?
Your answer better not be " you'll still be slow"
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
performance only racing, CRT, ultimate converter, superior design concepts, ThumperCarbs
