Quote: In the Vid the #5 intake rocker is Barely moving compared to all the other rockers. That lobe may be shot as well. Unless its some kind of optical illusion.
Edit, Well , unless you disabled the intake rocker instead of pulling the plug wire to test that CYL.
yup, #5 intake was backed off as well.
what I did, was I left the spark plug and plug installed, but unplugged the fuel injector so I wasn't spraying fuel at a cylinder I was "testing" I backed the intake rockers off first, then backed off the exhaust. On #5, once I heard the sound go away with the exhaust, I started playing with it, tightened it up, loosened it, tightened it, loosened it. every time it was tight with the valve working, the squeak was there. as soon as the exhaust valve was backed off, the sound went away.
