Quote: I heard this exact same sound years ago with a Mallory Unilite distributor. The rotor was sitting too low and rubbing the distributor body....not sure if this is your issue, but the sound is the same squeaking I remember.
stock distributor, EFI engine, but I'll check the rotor again. there's really nowhere for it to rub though, as there's the cam position sensor that's on a plate that's down into the body of the distributor, then the shaft sticks up 3 or 4 inches, and the rotor is up on top. there's nothing in between like on an electronic ignition distributor with the magnets and pick-ups etc.
