Quote: I would go the TQ route .....with a 904 trans.
FI still is a PITA, expensive and does not work right all the time.
Not if he would use the factory ECM and a Magnum engine.That setup is bullet-proof as far as dependability is concerned. He could even use the A-518 O/D transmission for even better economy and drive-ability.
Karma has no menu. You get served what you deserve.
