I only turn my water pump & fan on when I am on the return road. I will run them sometimes going out to the stagging lanes. This summer with the temp. 98-99 and the heat index 100-112 and the track temp 140 + the engine never got over 190 degrees. That has got to be a + for running alcohol.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
