I've changed to methanol(pro systems SV-1) picked up close to 2 tenths 12.5:1 CR.The only draw backs are hard starting in cold weather and a little more fuel system maintenance.I can purchase methanol locally for about $150.00/drum.So far I really like it.
Are you using the vacuum referenced regulator with the SV1?
