Quote: That means your block is a restamp-the B is not even close in size to the 3, not to mention they aren't the same font! Sorry, that's prob not what you want to hear!
I agree with Paul on this one, USUALLY the complete stamping (numbers spacing, alignment, etc.) should match very closely if not exactly, but the actual letter and number fonts should ALWAYS match in size and shape, they were each stamped moments appart by the same guy with the same stamping tooling on the production line.
