Quote: Just to clarify.... This is supposed to be the engine that blew up and was taken out(damage to the lower skirt of #4 cylinder)
....therefore having the numbers stamped at the factory....
It was removed from the car and replaced under warranty back in 1971 and somehow ended up in Ohio some 38 years later.
What did the dealers do with the dicarded engine blocks back then?
Well Alan, if this one doesn't pan out and since the warranty repacement 440 motor wasn't with the car either when you got it, watch for someone now doing a better job of restamping and contacting you claiming they have the warranty replacement motor....now where'd I put my stamps.
