also notice the PAD is twice as deep as most you see... indicating its been shaved..also the font is way way off as the spacing off the trans stamp would be the same so yes this is a FRAUD dan
And there are no remnants of the original Bridgeport milling machine marks with which all pads were milled whether they were stamped at the factory or unstamped warranty replacements.
I totally agree with you Bill; the Bridgeport milling is there no matter what and the alignment of the characters or numbers doesn't matter. This is a '71 C-body 440 engine I have (complete) that I know was stamped at the factory (no one in their right mind would re-stamp it as a non-HP 440 ) and if you look closely you can still see the Bridgeport milling marks . So the factory stamped it OuTofFAliGNmEnt and doubledouble stampp the 2 2
MikeR
